Re: 1941 H Farmall
Posted by c1802362 on May 24, 2009 at 16:36:28 from (72.221.72.70):
In Reply to: 1941 H Farmall posted by bodid1998 on May 23, 2009 at 07:10:24:
When I bought my "41 H the very first thing I did was drain and
change the fluids. The tranny was all brown water - just like
yours.
It should take about 6 gallons of 90 weight transmission oil. If
you can, buy the 5 gallon bucket. Its considerably cheaper in
bulk.
Keep an eye on the main housing to axle gaskets - Once I
changed the fluid, that joint started leaking from the bottom.
Apparently, draining the water loosened whatever dirt had
collected at the bottom of the gasket opening a nice weep hole.
Art
