Posted by CNKS on May 24, 2009 at 17:49:05 from (216.144.104.128):
In Reply to: model h # fbn107526 posted by Roy E. Mchenry on May 24, 2009 at 14:47:26:
Carb kits are available about anywhere, all the way from CaseIH to this site -- CaseIH is the most expensive. You might check the screen which is inside the fitting on the carb that you removed the fuel line from. If that is clean, disassemble the carb, let it soak for a while in true carb cleaner (preferably overnight) and blow out all passages with compressed air. Also, you said you cleaned the lines -- you might also want to check the opening in the tank that goes to the sediment bowl. That is a very common plugging area.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
