Re: Farmall C smokes
Posted by Janicholson on May 24, 2009 at 18:25:01 from (66.173.50.171):
In Reply to: Farmall C smokes posted by bigr on May 24, 2009 at 18:15:27:
If it smokes oil smoke, run it hard doing real work for maybe 5 to 8 hours. If it does not improve, pull the plugs and put 1/4 cup of ATF in each of the holes. put the plugs back in and wait 5 days.
Pull the plugs and place a old blanket over the holes. Crank it 15 seconds to blow out the excess ATF.
Put in the plugs and work it again (it will smoke from the ATF for a while, but if the rings can be loosened that will do it.
If it boils over, or it is Antifreeze smoke, it may be cracked internally. Have the head checked first, then block.
JimN
