Posted by CNKS on May 24, 2009 at 18:32:11 from (216.144.104.128):
In Reply to: Super H fuel problem posted by Jerry Upchurch on May 24, 2009 at 18:19:51:
You have already diagnosed the problem which is fuel flow. Clean carburetors can only be obtained for sure by disassembly and soaking them in carb cleaner. But, the problem could be further up. Check the screen in the fitting on the carb for the fuel line if you haven't already. Clean the opening out of the tank, make sure the line is clean. Running ok for a few days and then dying, indicates that something is plugged.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
