Re: f 20 clutch removel
Posted by SproutW on May 24, 2009 at 19:04:16 from (216.182.177.103):
In Reply to: f 20 clutch removel posted by heavy hauler too on May 23, 2009 at 11:37:34:
Remove all the bolts on the bell housing cover. The trick is to spin the entire cover and unbolt the pressure plate bolts through the inspection cover. Had to do this on several F-20's and then just pull the entire unit as one piece. I also keep the clutch pedal hooked up and pushed down on the pedal to help pop the cover loose. Let us know your progress.
