Re: Remounted carb now throttle races on SMTA
Posted by sflem849 on May 24, 2009 at 19:21:33 from (66.254.196.101):
In Reply to: Remounted carb now throttle races on SMTA posted by sflem849 on May 22, 2009 at 05:47:22:
I got it on my fifth try. Thanks for the help Rusty.
I found it easiest to take the carb off and hook up the governer. Then I could move the throttle and make sure it was moving the plate in the top of the carb. To make things interesting I wasn't able to get the gov tube in the carb with the carb low enough that I could see. I had to do it on the manifold (Not hooked up) then drop it down and check.
It is a pain no matter what way you do it. I can't believe I lucked out the first two times I pulled it. I sure did have trouble this time!
