Re: 1942 framall H help geting in time
Posted by SDE on May 24, 2009 at 20:49:36 from (75.121.155.217):
In Reply to: 1942 framall H help geting in time posted by papa woody on May 24, 2009 at 20:08:43:
With the cap off, Turn the engine over with the hand crank. Check the direction that the rotor is turning in the distributor. Now check the cap to see if the firing order is in the correct order for the direction it turns. It is a simple mistake that happens sometimes.
Turn the engine over until the rootor is pointing in the direction of the #1 tower of the cap. Look at the timing mark on the front pulley. If it does not line up to any of them, you are most likely off by 180 degrees.
Steve
