Re: Starting engine after rebuild
Posted by Janicholson on May 24, 2009 at 21:14:48 from (66.173.50.171):
In Reply to: Starting engine after rebuild posted by Mr Mayor. on May 24, 2009 at 20:40:35:
I would use a squirt oilcan to fill the galleries and oil filter. Just use a rubber tube to connect to the oil pressure port on the engine, and pump several oilcans full into it ( you will feel it become filled when pressure on the oilcan trigger increases )
Polarize first engine off, then just leave the key off and plugs out when cranking. It will have pressure almost immediately if you precharge it as above. Then start it. Run for 15 minutes, then retorque the head and set the valves again. JimN
