Re: 1951 FARMALL C
Posted by Janicholson on May 24, 2009 at 21:17:42 from (66.173.50.171):
In Reply to: 1951 FARMALL C posted by burnsg on May 24, 2009 at 20:54:23:
A warped gasket seating area can cause leaks. Check carefully to see where it leaks from. If the bowl seal, flat sanding it on glass with 320 paper will get it straight. Look at the gasket to see if some areas are pinched while others are not. JimN
