Remove the oil pan and apply pressure to the radiator. You only need about 5 psi and then look for any leaks around those seals. They get like an old shoe left out in the weather over time. If there's a leak the engine needs to be completely torn down and that area around those seals needs to be thoroughly cleaned of any rust or dirt. I would have the block cleaned & install new sleeves & pistons. Have the crankshaft measured for wear as it may be worn some. Have your local machine shop furnish the correct new bearings too. Get the head redone and it will be good for another 50 years. Hal
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
