Re: Dreaded Antifreeze in Oil
Posted by Janicholson on May 25, 2009 at 08:18:57 from (66.173.50.152):
In Reply to: Re: Dreaded Antifreeze in Oil posted by Larry Hardesty on May 25, 2009 at 07:56:11:
The radiators can only stand 7psi (do not use more)the tank metal will break at its seams.
I also believe the Orings are probably at fault. I believe that A treatment with ground black Pepper (about 1/4 cup), or Bars Leak can seal up leaks permanently. It is worth a try and cheap at that.
JimN
