Re: Dreaded Antifreeze in Oil
Posted by Mark Peters on May 25, 2009 at 08:42:21 from (66.222.6.79):
In Reply to: Dreaded Antifreeze in Oil posted by Larry Hardesty on May 25, 2009 at 06:49:59:
Jim. What`s the deal with the ground pepper? You just take a 1/4 cup of it and dump it down the radiator? Not to hijack this thread ,but ,I have the same deal going on as Larry.I have a Farmall 240 with very low hours (577) that showed some anti freeze in the oil the last oil change. I suspected o-rings right from the start because the tractor just sits all the time and is used very little.I don`t want to tear her apart if I can get away with it as I believe the pistons and sleeves sure shouldn`t need replacing.
