Re: One arm loader control valve uses for live connection?
Posted by TractormanNC on May 25, 2009 at 14:58:38 from (209.42.180.80):
In Reply to: One arm loader control valve uses for live connection? posted by MF40Industrial on May 25, 2009 at 07:24:43:
MF40,
The valve shown in your pics is the factory valve used on Super A, 100,130,140 for double acting remotes. It was used on the Super C, 200, 230 for the Fast Hitch cylinder. Was not used with the loader. The valve you show WILL work a double acting cylinder. Had a 1000 loader years ago, it had a two spool double acting power beyond valve plumbed into the hyd with a bypass block between the hyd manifold tubes and the touch control block.
