Re: Farmall H Engine Spacers?
Posted by wayne in mn on May 25, 2009 at 20:48:51 from (66.188.165.73):
In Reply to: Farmall H Engine Spacers? posted by farmallboy1994 on May 25, 2009 at 18:45:19:
Do you mean washers? They go under the head nuts where the surface around the head bolt hole looks different. Test install the head (no gasket) to be sure the bolts stick up far enough to allow full thread contact with the nut. Sometimes the bolts will get threaded too far down into the block.
