Re: Farmall H Engine Spacers?
Posted by ScottyHOMEy on May 26, 2009 at 05:46:59 from (71.241.207.162):
In Reply to: Farmall H Engine Spacers? posted by farmallboy1994 on May 25, 2009 at 18:45:19:
Just a quick run down through the parts associated with the head, I don't see anything that there's three of listed, but then they're different sizes so they'd have diffeent numbers anyway . . .
What are you calling spacers? Are they like thick washers? Just wondering if they might be 3 of the 4 washers that are used on the four manifold studs. The ends of the manifold bolt right down, but the four studs in the middle take a washer to allow the seams cut into them to expand and contract. If they're made of a bronzish type material, that may be where they came from.
