Re: M--MTA--Char Lyn
Posted by paul smta on May 26, 2009 at 09:13:13 from (68.117.10.58):
In Reply to: M--MTA--Char Lyn posted by Marvin Ky on May 25, 2009 at 20:32:43:
If what you mean by motor is the pump the hood on a smta is longer than an m.Mine is mounted just above the govenor and is powered with a belt that runs off the water pump pully and generator in line,one mounting bracket is slotted and uses one bolt from the manifold.My thought,mabe wrong mounting hardware.Hope this helps.Paul
