Re: Super A coolant leak
Posted by ScottyHOMEy on May 26, 2009 at 14:32:46 from (64.222.246.164):
In Reply to: Super A coolant leak posted by Cue P. on May 26, 2009 at 14:15:53:
If you're seeing it that high up on the outside, it could be a crack somewhere in the head, but I'd sooner suspect a gasket issue.
If you're really lucky, it may be as simple an issue as the head never having been retorqued after being run after the rebuild and youmight be able to close your leak up with regular torque specs (80 ft-lbs). The more recent the rebuild, the better your chances on that option.
The only freeze plug is inside the torque tube, one th rar face of teh block and requires removing the flywheel to get to it. That wouldn't be showing up where yopu're finding juices.
