Re: farmall 200 won't charge battery
Posted by wolfman on May 26, 2009 at 17:02:49 from (174.140.65.158):
In Reply to: farmall 200 won't charge battery posted by kuntryboy on May 26, 2009 at 16:53:14:
Double check that it is hooked up pos ground.
