Re: farmall 200 won't charge battery
Posted by Janicholson on May 26, 2009 at 17:04:11 from (66.173.50.161):
In Reply to: farmall 200 won't charge battery posted by kuntryboy on May 26, 2009 at 16:53:14:
With respect, the voltage regulator is not polarized, it is the generator that is polarized.
With the tractor off, Jump briefly between the Bat terminal and the Gen terminal on the regulator(not Field). This puts magnetism into the iron generator poles. JimN
