Re: 966 tire wear
Posted by Hugh MacKay on May 26, 2009 at 17:41:13 from (209.226.247.9):
In Reply to: 966 tire wear posted by GordoSD on May 26, 2009 at 16:20:56:
Gordon: Tire pressure and toe in are very important. Low pressure coupled with too much toe in will peel the rubber off. Try turning the tires on the rim, so other side is out. Set the toe in so front is 3/16 to 1/4 less at front of axle than behind the axle. Take that measure at axle height. With a tractor that size, got with 50 psi.
