With the engine running at governed ROM and a healthy charging system, voltage measured from the generator A to ground will be between about 6.8 and 7.5 volts. If the cutout relay (inside the regulator) is not working you might see 15 – 20 volts or more. And if the generator itself is bad voltage will less than 6 volts.
The voltage between F and ground ranges anywhere from zero to 4 or 5 volts depending on engine RPM, the level of charge in the battery, amount of external load (lights, etc) and generator temperature.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
