Re: Generator charging questions
Posted by Janicholson on May 26, 2009 at 18:52:08 from (66.173.50.173):
In Reply to: Re: Generator charging questions posted by a_lead on May 26, 2009 at 18:17:37:
Another suggestion is to eliminate the Amp gauge temporarily if it is bad. Without a battery to charge, some regulators will not behave at all. All charging current goes through the meter. Just connect the two terminals together (it will be OK)
JimN
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
