Re: farmall 200 won't charge battery
Posted by gene bender on May 26, 2009 at 19:00:38 from (67.55.227.59):
In Reply to: farmall 200 won't charge battery posted by kuntryboy on May 26, 2009 at 16:53:14:
Batt should be 6v and pos ground. Is that what you have?
