Re: Generator charging questions
Posted by John T on May 26, 2009 at 19:29:29 from (66.244.97.31):
In Reply to: Generator charging questions posted by a_lead on May 26, 2009 at 17:59:05:
The open unloaded output of a genny from its ARM post to case ground dont tell ya all that much, its what it can do to the battery voltage once running n connected via a working cutout relay. Id expect the battery sitting there to be 6.3 volts but if hooked to a good charging system Id expect battery voltage to rise to 6.5 to 7 and a lil over
My Para 5 will tell if its a genny versus a VR problem
If it passes BOTH my Para 8 Motor tests, it should charge
Let us know
John T
