Re: v-belt pulley for a
Posted by mkirsch on May 27, 2009 at 04:57:33 from (64.80.108.56):
In Reply to: v-belt pulley for a posted by pheel on May 27, 2009 at 03:39:47:
To get the mower to spin at the proper speed, you will need an 18" pulley for the main PTO, and you will need different blades with the sharp edges on the opposite side.
Belly mowers on Super As are driven off the flat belt pulley gearbox, not the PTO.
