Re: wheel configuration for A Farmall
Posted by mkirsch on May 27, 2009 at 05:12:40 from (64.80.108.56):
In Reply to: wheel configuration for A Farmall posted by Terry Hales on May 26, 2009 at 15:00:51:
Hi Terry,
The owner's manual has a diagram with all the possible combinations of wheel widths. You can get reprints from many sources so you can have one in hand while you're out in the shop.
Just FYI, but the wheel centers are supposed to be different from left to right on a Super A. The right wheel should be a heavy cast steel, and the left should be a lighter stamped plate steel. This is to balance the tractor out and keep it from tipping over to the left due to the offset engine.
You can add up to two 140lb cast iron wheel weights to each rear wheel of the tractor for additional ballast.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
