Re: gas in crankcase oil
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bob M on April 11, 2000 at 18:09:13 from (205.188.192.167):
In Reply to: gas in crankcase oil posted by Charlie M. on April 11, 2000 at 17:24:03:
Charlie - Check your thermostat. If the motor is running cold, it will build up gas (and condensation) in the oil very rapidly, even with good rings.
If your tractor does not have a heat gage, a good rough test is to touch the upper block/head beween two spark plugs after the motor has run 10 -15 minutes. It should be hot that you can only touch for an instant. If it's only warmt, replace the t'stat...
Post A Followup
: Re: Re: gas in crankcase oil
