George - It could be as simple as the ammeter wired is backward on the one showing discharge.
If the tractor has lights and/or battery (not magneto) ignition, with the engine stopped turn on the lights or ignition and observe which way the ammeter needle swings.
If the needle swings right (shows charge) the ammeter is wired backward. Simply swap the wires between the two ammeter posts and you'll be all set. For safety disconnect the battery ground cable before fooling with the wiring!
However if the needle swings LEFT when you do the test above it says the ammeter is working correctly - the problem then is the alternator.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
