Posted by Haas on May 27, 2009 at 13:43:54 from (12.65.6.139):
In Reply to: rear end oil posted by Reel on May 27, 2009 at 13:11:23:
I wonder if you realize, that there is an inner and an outer seal on the axle housing. The axle housing has to be removed from the tractor to replace the inner seal. The outer seal is only a grease seal as the outer bearing is only lubed with grease and there is not supposed to be any oil out at the end of the axle. The inner seal is near the transmission housing and keeps the oil in the transmission and out of the axle housing. So...if you just do the outer axle seal, it probably won't cure the leak. I have a C which is similar and I have resigned myself to live with the leaking axle seal. Some grease in the fitting for the outside bearing will help reduce the leak.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
