Re: farmall c Carb visit 2
Posted by Janicholson on May 27, 2009 at 16:23:41 from (66.173.50.144):
In Reply to: farmall c Carb visit 2 posted by Eric Phipps on May 26, 2009 at 13:32:38:
Yes a poor coil will contribute to hard starting. Intake manifold leaks can also act the same way. Use an unlit propane torch with the tip removed to find possible leaks in the gasket area or cracks. (do it outside, and don't turn the torch open much, just as though it was a low flame. You are feeding fuel into a leak that will speed up the tractor.
JimN
