Bill - The copper terminal button on the starter case under the switch acts as part of the starter switch. It wears each time the starter is used. Over time the button gradually wears down so even a new, factory OEM switch will not make proper contact. A new switch thus quickly burns out.
The only fix is to take the starter to a starter shop and have a new button installed - about $25 or so. With a new terminal button on the starter even a cheap starter switch will now give many years of reliable service.
You CAN replace the saddle (manual) starter switch with a solenoid. But you'll need to have a threaded stud installed to replace the starter terminal button so you can connect a cable from the solenoid to the starter. You also need a separate starter switch and more wiring - ie. more stuff to go wrong.
If the tractor was mine I'd stick with the original style manual switch...
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
