If your 784 has the hand pump like similar models such as the 606, 656, and it is the top seal that is leaking, it is easily replacable after you remove the steering wheel. There is a cap and felt washer under the wheel and then a snap ring holding the seal in place. You can crank the engine and let hyd psi blow out the seal, loosen a line and blow compresed air into the hand pump, or some say you can put the wheel back on and give it some turns/jerks to loosen the seal. Go to casih.com and do a search for parts and enter the 784. You will need a puller to pull the wheel and maybe a little heat. Check the archives here for more info.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
