Re: 400 hyd won't pick it up
Posted by Hugh MacKay on May 28, 2009 at 08:58:58 from (209.226.247.127):
In Reply to: Re: 400 hyd won't pick it up posted by farmallmechanic05 on May 28, 2009 at 05:41:09:
Kirsch has the best idea for testing, raise it high as it will go then add oil. He says pipe, however I'd screw a 5-6 foot hydraulic hose in the filler plug stick the end in a pail, because as he said, "when you let it back down your going to have too much oil".
If that cures it then you know additional reservoir will work. Nice to know these things will before you spend money.
If running out of oil is your problem, then thightening the helper springs wont help. I don't know much about these discbines, however on haybines one set the helper springs so an able man could lift the header by the push bar. I would think a discbine wouldn't be much different or it would be gouging the sod.
