Re: Throttle Lever Problem on Farmall M
Posted by GeneMO on May 28, 2009 at 09:51:01 from (65.174.132.35):
In Reply to: Throttle Lever Problem on Farmall M posted by Melvin Ware on May 28, 2009 at 09:19:35:
You can take the whole assembly apart and its pretty apparant how it works. My spring was broken so a trip to Westlakes found a suitable replacement.
Then I put a spot of weld on the lever and using a file put a new edge on it.
Mine has sawtoothed shaped notches. Some I have seen are square notches.
Finally, I had some wear in the post area. I found that a .40 caliber pistol case was the right diameter. I cut the head off and used the brass case for a bushing.
Cleaned it all up, painted it and it works like new.
Good luck,, Gene
