Re: Throttle Lever Problem on Farmall M
Posted by mkirsch on May 28, 2009 at 11:27:43 from (64.80.108.56):
In Reply to: Throttle Lever Problem on Farmall M posted by Melvin Ware on May 28, 2009 at 09:19:35:
It's normal for the tension to get tighter as the throttle is opened. That is the governor springs doing their job.
You need a good tooth on the throttle lever and good clean notches in the "hat" on top of the steering post. Most of the time the little tooth is worn from previous drivers "ratcheting" the throttle instead of pulling the lever clear of the hat before moving it.
