Re: Throttle Lever Problem on Farmall M
Posted by Roy Ward on May 28, 2009 at 12:32:36 from (66.82.9.54):
In Reply to: Throttle Lever Problem on Farmall M posted by Melvin Ware on May 28, 2009 at 09:19:35:
I did notice you can buy the pin that has a nut that bolts threw the handle and also the top cap. But I did what GeneMO did. I used a brass rod to build it up. I had also some worn teeth on the cap so I used dremel with a small cutting wheel to square them up.
