Re: McCormick-Deering 10-20 done! (2527)still can't crank...
Posted by dave.koenigsfeld on May 28, 2009 at 15:46:53 from (75.25.103.209):
In Reply to: Re: McCormick-Deering 10-20 done! (2527)still can't crank... posted by El Toro on May 28, 2009 at 13:48:06:
I found an old belt in the barn when I got the tractors. I will have to go down to the ranch and pick it up to see if it is long enough to reach.
The sediment bowl does have a shut off but it does leak down into the carb. I checked the floats and they seem to be clean and in good shape.
The plugs never seem too wet but I do get some drips out of the carb.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
