Re: McCormick-Deering 10-20 done! (2527)still can't crank...
Posted by James Williams on May 29, 2009 at 00:13:36 from (170.215.131.125):
In Reply to: Re: McCormick-Deering 10-20 done! (2527)still can't crank... posted by dave.koenigsfeld on May 28, 2009 at 15:06:56:
If it snaps just past TDC and you set your mag at the retard position the piston is probally to far down when firing causing lower compression
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
