Re: McCormick-Deering 10-20 done! (2527)still can't crank...
Posted by El Toro on May 29, 2009 at 04:05:02 from (64.12.116.73):
In Reply to: Re: McCormick-Deering 10-20 done! (2527)still can't crank... posted by dave.koenigsfeld on May 28, 2009 at 18:34:44:
It should be long enough so there's plenty of clearance between the 2 tractors. Make sure you set the brake lever too on both tractors. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
