140s do not have a "rear lift" either from the factory or as a common option. They have two front rockshafts, one of which is usually connected to a rod that moves a rear rockshaft. Is that what you have?
If not, then you have something that's aftermarket, and you'll need to describe it better.
I think the drain plug being under pressure is normal. You need to remove the fill plug to relieve the pressure first, or you end up covered in HyTran oil.
The touch control (which is what the hydraulic system is called) blue ribbon service manual is available at http://www.cleancomputes.com/Cub/Blue%20Ribbon%20Service%20Manuals/GSS-1024%20Touch%20Control/index.html
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
