Re: 966 questions
Posted by mkirsch on May 29, 2009 at 08:24:43 from (64.80.108.56):
In Reply to: 966 questions posted by DK44H on May 28, 2009 at 22:01:54:
Wouldn't hurt to make sure everything is adjusted properly, regardless.
Adjusting the clutch won't change the jerkiness, though.
It's a specific process detailed in the owner's manual and I&T service manual. I suggest you get one of these and use it to make sure the adjustment is right.
