Mac: To start with the tractor transmission-rear end and hydraulic are two separate compartments. Use hytran in the hydraulics and gear oil in transmission-rear end. Forget about what Kirsch's manual says, mine says the same yet we all use gear oil in those little transmissions. If we didn't, we'd grind a lb. of gear steel everyday.
Your tractors transmission is probably overfull, 65% of transmission-rear end seal leaks are caused by too much oil in there. Usually it is a mixture of gear oil and water, because these tractors leak more water down the gear shift lever than down the stack if both are left uncovered in the rain. Put a bucket over the gear shift lever. If it's just overnight don't worry about the stack.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
