Re: Throttle Lever Problem on Farmall M
Posted by deamer1 on May 29, 2009 at 10:39:55 from (12.213.112.52):
In Reply to: Throttle Lever Problem on Farmall M posted by Melvin Ware on May 28, 2009 at 09:19:35:
Yesterday I repaired my Model 200 with the same problem. I used a dremel tool to shape the notches better. Just go slow and look it over as you work. I disassembled the lever assembly, replaced the spring and cotter pins.
My lever had worn down so much that it had a grove worn in the part which should fit in the notches. I was using a wire to hold it in place. I welded (mig) to the handle and then shaped it with a small grinder. This worked fine. Upon complete reassembly it works like a new lever. Good luck and may the good lord take a liken" to ya"
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
