Re: farmall 656 gas
Posted by John G. Hasler on May 29, 2009 at 13:39:24 from (75.121.194.135):
In Reply to: Re: farmall 656 gas posted by Deamer1 on May 29, 2009 at 12:01:22:
> Have you got some words of advice for me? I"ve
> never done anything like it.
Plan every step and think about what might go wrong. The tractor is heavier than you think it is, no matter how heavy you think it is. Use stout cribbing to support it: not just a jack. If it falls on you it is likely to kill you (or leave you wishing it had).
Also think about how you are going to get the new axle into position. It is also heavier than you think it is. You aren"t going to be able to hold it up with one hand and put bolts in with the other.
