Re: Need some guidance on tires...
Posted by ScottyHOMEy on May 29, 2009 at 16:04:12 from (64.222.246.164):
In Reply to: Need some guidance on tires... posted by Dave H (MI) on May 29, 2009 at 15:10:57:
I'll go out in a minute and see what I might scrape up for sources.
As far as size, the ground under a trailing wheel in a field is going to be irregular enough that 1/2" in radius isn't going to really mess you up. A more significant undersize could easily be cured by lifting the plow a notch or two if the smaller wheel lets it run too deep to pull. An oversize wheel, to my mind, would be more of a problem in that it might keep you from cutting as deeply as you want to, or tip the plow forward to where it's biting at a steeper angle than works well.
I'll look at some old catalogs and google a little on the tires and see what I can come up with and let ya know.
