Re: Farmall A wiring
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Farmer Bob on April 11, 2000 at 21:36:42 from (207.227.187.147):
In Reply to: Farmall A wiring posted by Paul on April 11, 2000 at 20:26:04:
Paul, Sounds like you did pretty good without a manual....if your light switch has 4 positions on it they are:
Fully Counter Clockwise = Low charge (No lights)
Next position going clockwise = High Charge(No lights)
Next position clockwise= Dim Headlights/Bright tail light
Last position going clockwise= All three lights on bright.
If you only have a 3 position switch....
Fully Counter Clockwise is "OFF" (But battery should still charge)
Next position clockwise is Dim front lights bright back light.
Last position going clockwise is all lights bright.
Hope this helps. I'm also emailing you a schematic for a 4 position switch, 6 volt, positive ground system if you need it.//FB
Post A Followup
: Re: Re: Farmall A wiring
