IH plow beam question....
Posted by Clefus on May 30, 2009 at 11:36:06 from (98.21.81.244):
I looked at 3 bottom rigid beam trailing plow at auction and was wondering if the trip beam bottoms ( I have a fast hitch plow) are interchangable with the rigid beam bottoms.....I thought about finding a trailing plow and using the entire bottoms from mine if I found another rigid beam plow....
Thanks
Dave
