Before replacing it use a test light to see if there is power on both sides of the resistor. The tractor has probably been converted to 12v. which (if it has the original coil, or a 6v replacement, or a 12v coil that needs the resistor, it must be there. Almost any mid 60s chevy or chrysler ballast resistor will work. By passing the resistor for a minute will not hurt anything. Check the points and set them to .020" when they are open by the bump of the distributor cam. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
