Posted by CNKS on May 30, 2009 at 17:56:11 from (216.144.104.128):
In Reply to: Hydraulic Leak posted by Farmall Bob in CT. on May 30, 2009 at 17:51:28:
Depending on the model of the pump (IH used more than one), you need to replace the o-ring or seal on the shaft. Remove the pump and it will be self explanatory. If the shaft has a significant groove in it, it needs a speedi- or redi-sleeve (trade names). If it has an o-ring, take the pump to a machinest and have the hole the shaft goes thru enlarged to accept the sleeve.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
