Re: H low oil pressure
Posted by Janicholson on May 30, 2009 at 18:30:06 from (66.173.50.83):
In Reply to: Re: H low oil pressure posted by CJ_1080 on May 30, 2009 at 18:14:46:
Do the oil first. then if not satisfied, the cover plate on the oil pumps often warp. This causes a leak and will lower pressure. Flat sand the plate with 320, then 600 silicon carbide paper on a glass plate. End clearance should be .001 to .0005"
adjusted with thin gaskets from IH. JimN
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
